Extruding to inside of shell
I am attempting to extrude to the INSIDE of a shell but the extrusion carries through to the OUTSIDE of the shell. I know that it is possible to set an offset from the outside surface, HOWEVER, if the shell is not of uniform thickness or has internal details then it becomes complicated.
Is there a way of extruding to the interior of the OBJECT (ie. internal surfaces), directly.
1 Comment
Suggest you post this in the Design, Validate & Document forum!
