Export sketch text in DXF correctly
Steps
I'm using AF360 2.0.1909.
I create a sketch on a plane, add some shapes and some text.
I exit the sketch, and Save as DXF.
I open the DXF sketch in Inkscape.
I choose the default DXF import options. (automatic A4 sizing, Latin1, Arial).
Result
Text appears as a single block rectangle.
Should be
Silouhette of each letter, including interiors of letters like 'o' and 'a'
Current Workaround
In Fusion360: edit sketch, right click on text and choose "Explode text".  Text is no longer editable (boo) but does export correctly.
4 Comments
Got the same issue. It's a pain to work with our electronics design as I have to explode the text every time.
Same issue here as well
promm
@i-make-robots,
The dxf export inside of sketch does not give you options when you export.  This is not the desired workflow and the team is exploring which environment to provide a real .dxf export.   Here is the list of enhancements we will be working on for the real dxf export.
  1. Discoverability
  2. Save to previous version (back to 2000)
  3. Layers
  4. Colors
  5. Text (notes)
  6. Selection in export - auto-clean
  7. Preview
  8. Scale
Once the we implement the new export, you will get the expected behavior for notes.
Cheers,
Mike Prom
eugen373
Community Visitor
it's been 2 years now..still the same shortcomings.
any idea when your are going to implement/fix this?
