Export Parasolid Fusion 360
 It seems to me that Parasolid is a more prefered export format than STEP if possible.
20 Comments
schneik-adsk
This is not our experience. STEP can be read into almost any other 3D CAD tool. Parasolids requires other CAD companies to write or license the parasolids translation library. I can under stand adding X_T and B_T parasolids format support, we just don't see it as more popular.
cekuhnen
Yeah - oddly nearly everybody I just over the summer I talked to (process interviews) in mold making mentioned parasolid being prefered. This was new to me as well - it is an area I am not very involved in.
STEP sofar served well. But it wsa mentioned for design modifications if the design was not done natively in SW parasolid seems to be a more popular choice for direct modeling alterations.
TrippyLighting
The company that machines the parts for my lamps also works with parasolids and I've sent them X_T fles in the past. The ideal setup would of course be if they'd start using Fusion 360. That would alleviate many things 😉
Currently I neet to export from Fusion 360 to STEP import that into Geomagic Design and export into parasolids from there.  I don't do it that often so it's more of a nuisance than a real limitation
odolyte
I may be wrong but Parasolid is a Siemens proprietary format. In order to manage it Autodesk would have to pay royalties i think...
cekuhnen
@odolyte Yeah Siemens bought it.
Now my question is then actually is what is the point of Parasolid vs STEP? I know Parasolid is also a modeling kernel.
But for data transfer where is the advantage?
charegb
Status changed to: オートデスク審査落選
We are looking at supporting export to some native formats early next year. Are there any others that would be useful for you?
Bankim
Parasolid Export is a must
elcolt
Community Visitor
Hey wonderful Fusion Team - yes I'm trying to suck up,
Please make exporting to Parasolid X_T a possibility. All the suppliers I send files to want them in X_T format.
Any chance it could happen soon?
Jimmyfabs
I would love a parasolid export feature as well!
to charegb
We need also CATIA V5 export and *.3dm.
I wanted to say as well, I have been asked to send files as Parasolid XT format as well. Very difficult to convert. I have to upload to Onshape then convert to parasolid, does not translate very well. Please make export option!
I just went to export my first Fusion 360 part file as a parasolid and it was not an option. So I checked and came across this thread so figured I would promote parasolid as a need. I always request a parasolid from customers when a part model is needed and always provide one to CNC programmers in the shop (also at their request). The single imported body is clean and easy to work with and most often requires no repair work like iges or step (which don't always open and need to be resent). Another benefit of parasolid is that I believe it is a much smaller file size over the other 2 which makes it easier to send around on email. -Art
carl-bartlett
Apparently with new updates in Fusion machine shops are having issues setting up for CNC with STEP files. They are corrupt or have a kernel issue. The shop I just sent a piece to says a Parasolid XT usually takes care of it.
Is there any progress on getting this?
Dan_Margulius
Hi
Any news with this?
Still no XT on the export options.
Dan
Parasolid X_T
Hallo,
it would be great to have this export possibility in fusion 360:
Parasolid X_T
Best regards
YanivBA
Working with offshore supplier, I'm keep getting asked for PARASOLID (XT) files. I understand that overall it's not considered the most popular but maybe someone can pick the glove and create some add-ins for that? Unfortunately many locations around the globe still have slow connections or blocking. so more file format especially small like XT are always helpful...I hope that's a strong argument 🙂
It seems this have been a topic here for over three years and Autodesk have no intention of supporting the community with a parasolid export? This doesn't make sense to me at all.
The least you could do is to point us in the direction of a solution provided by someone else if you fail to see that you should have this support in Fusion 360.
2018 Mazak does best with a parasolid for extracting geometry for conversational programming. CAM software is irrelevant. When defining lines and excessive holes, a parasolid does wonders.
We were thinking of transitioning our whole CAD department over to Fusion 360, but no Parasolid support is a deal breaker for us.  Any update on this?
Hi, Fusion 360 developer guys,
This is the issue with neutral CAD files (STEP, IGES, Parasolid, JT, etc):
Customers send files for manufacturing in any available neutral CAD but the preferred format to start programming with CAM software is Parasolid.
This is the reason:
STEP files split original circles into 2 semi-circles
IGES convert circles into splines or curves
And so on...
A Parasolid neutral file keeps a circle as is, so CAM software (for instance Gibbs CAM) can put a G02  or G03 line of code to mill an arc.
So, our CAM programmer requests our CAD designer to open the customer's files into SolidWorks and save as Parasolid.
Another issue: CAM programmers don't have enough time to learn a new CAM software, so they don't want to move to Fusion 360.
Today you can't convert a neutral CAD format to Parasolid using Fusion 360.
