Expansion of comment field in parameters table
It is difficult to read or edit long comments in the "Comment" field of the parameters table.
Microsoft Access database provides an example of a good way for an improved user interface.
In that programme, when the cursor is in a field, by hitting the Shift + F2 key a larger window opens, facilitating viewing or editing of the entire comments field as a result of it being show in a larger and multi-line view.
Example of expansion of database field by hitting Shift + F2Example of expansion of database field by hitting Shift + F2
As a further improvement (which I believe many others have also requested),
there should be a facility to re-order the parameters table.
It would be particularly useful to be able to sort by parameter name.
Ideally, it should also be possible to sort by any other field or even by a combination of fields.
Again, Microsoft Access database (or Excel) provide examples of reasonable user interfaces.
