AutoDesk Fusion 360 is a great product, but many users get lost when trying to figure out how to integrate it with the real world.
Please push your evangelists and product managers to improve the following areas:
Tool Library > Vendors.
I currently only see vendor options for tool holders. Improving the tool library has been mentioned elsewhere, but I believe AutoDesk should try a small update where you work with a Tool & Die vendor to bring their part library online. I think you'd be amazed at how AutoDesk has the ability to drive sales to specific vendors, and users would save a huge amount of time by choosing a vendor and part # and having all the relevant info autopopulate into the fields (feeds and speeds included). Try a small vendor to setup the standard and then make it part of your large Tool Library update after getting early feedback. Destiny Tools in Santa Clara, Shopbot's handful of OSGURD. You can then move on to Tools Today, Amana, McMaster Car.
Post Process
Your CAM Post Process list is where a lot of new users get lost. It is just a huge list with no additional info. Your webpage at: http://cam.autodesk.com/posts/ has a lot of really useful info, like a version # and what was fixed log. You need to rework the Post Process list so that users can filter out the post processors they don't use. The basic UI should be similar to the Tool Library to encourage familarity in how to setup post process. Add additional info to each PP that includes what CNC machines are supported. Dump.cps should have a new SUPER Version that lets users export everything to a G-CODE editor of their choice. You need to let vendors link their post process with an external app for loading and checking the G-Code.. You need a link in the post process window where users can link directly to a specific Post Process forum group where users using this PP can find and talk with others using the same PP. http://forums.autodesk.com/t5/post-processors/bd-p/218 - this needs to have a concept of vendor's Post Process Sub Folders for messages.
Add-Ins
Celebrate the most important part of AutoDesk Fusion 360! Please work to get more vendors writing Fusion specific Add-Ins. This will tie your universe and theirs into much tighter integration. 3D printers seems like they've made some headway, but having some showcase examples would help immensely. I like the Add-In McMaster-Carr, but it is missing a quick sort field for finding parts with CAD drawings (you have to search the part and then check to see if it has it, would be nice if you could auto filter on this setting). It is also bad that McMaster showcases Solidworks as the default import type with Fusion kicking back an error and prompting the user to choose between SAT or STEP with no indication which one is better. Please work to make the McMaster-Carr integration better and to push them towards releasing an Autodesk standard as the default option. You should also work to get other vendors integrated ASAP.
