Enhancement: Horizontal/Vertical or Midpoint Constraint
First of all, let me start of with how much I loved the unified Horizontal and Vertical Constraint. However I would like to request an additional enhancement to it.
Right now we have the midpoint constraint but it can't do what I want to do as I described below and I feel the Horizontal Vertical Constraint will work better here.
As in the image above, I can't align the 2 points to the center of the top line, unless I manually dimension them to be in the middle.
4 Comments
Hey O.Tan, I also would like a lot better constraint functionality, do you know how spoiled we are from our previous system in this area? 😉 🙂
You can create a point, make it a midpoint on either line, and then use horizontal for any other points.
You can also draw a construction line from top mid to bottom mid, and then use coincidence.
https://screencast.autodesk.com/main/details/900eadac-5224-41eb-bd95-aadd7d857223
brianrepp
Status changed to: Gathering Support
colin.smith
james.thornburgh
I just noticed that the ability to use a midpoint for Horizontal/Vertical has stopped working.
