Edit UI BUG: Move preview for long distances gets the computer fully stuck
Prepare:
- open some model and create a solid body (I had a plate with three corners, each cut by a circle)
Steps:
- start to move a solid body (the whole body, right click from the browser)
- first enter 25000mm as the direction to move (observe that preview is fine and machine works normally)
- start editing the number to 24995mm starting by adding numbers in the middle
Expected:
- editing a number in such way should be okay, as well as the eventual number is less-than-astronomical
Actual:
- the whole machine gets stuck, until (after 25 mins) I did a Force Quit on Fusion (with great difficulty - the machine was so stuck)
Cure:
if move numbers would lead the preview too far (outside of the viewport or too far into the horizon), preview should not even try to do this, until the numbers are confirmed (that is, 'OK' is pressed)
Even in the case of pressing 'OK' for a distance s.a. 249955000mm, the above (full stuck machine) should not happen.
Versions:Fusion 360 1.8.568, OS X 10.8.4
1 Comment
promm
Status changed to: RUG-jp審査通過
