Easy way to mirror a part with CAM operations
Sometime i must mill a part like it was drawing and mirrored.
In Fusion 360 i can mirror the CAM Toolpath, but then this toolpath is ccw not cw i want !
So i mill the part as drawn and then i mirror the toolpath. Also i switch the direktion to ccw, so if it was mirrored, it is cw.
But then, i see some drawing bugs !
https://forums.autodesk.com/t5/fusion-360-deutsch/werkstuck-mit-cam-werkzeugbahnen-spiegeln/m-p/7661...
(sorry, only german, but see my picture)
And this solution is not ok for me. I must edit the directions of all operations ... and the stock is not ok also.
So for users they must mill this parts, a mirror funktion (that use the same mill direktion like without mirror and use a mirrored stock) will make it easy to produce the parts.
1 Comment
I am having the same issue.
Spent a few days programming this part, only to find out that the mirrored operations are now conventional milling instead of climb milling like the original operations!
Is there a fix for this?
