I would like to request that F360 display a warning when the user performs an editing action, on a sphere-based form, which creates "coincident vertices". Presently, the coincident vertices warning only appears when one clicks on Exit Form, which can be long after the action that created the issue occurred. To fix this error, the user has to run the Repair Body utility (which can introduce unwanted deformities) and/or the user has to click the back button to the point where the error occurred (attempting "Exit Form" along the way) and then redoing the change more carefully.
I ran into this error recently while attempting Mr. Sharma's spoon-creation exercise in the Udemy Design class, and so I started this forum thread (see it for issue details):
Then today, I moved on the the subsequent (Rubber Ducky) exercise, and ran in to the same "coincident vertices" error at the end of the lesson when I attempted to Exit Form. So at one point, after backing up to the middle of the lesson, I did a Fix Form action. The result was that all the lateral vertices were deleted, as shown here:
Of course, if the editing code could be adjusted so that the underlying coincident vertex condition doesn't occur so often in the first place, that would be a plus!
Thanks!!!!!
Kurt
