Hello Community,
i have experienced a common problem with my designs. While exporting DXF-Files from sketches, they are useless when opened with a third party program. I found a workaround on the forum that works. The basic problem is that Fusion uses the highest version of the dxf Format, but a lot of other systems can´t read that. So it would make things much easier, if it would be possible to choose which format will be used to export the dxf.
