DXF export to LaserCut 5.3
The current Fusion 360 DXF format doesn't import directly into LaserCut 5.3.
The workaround is to import the DXF into Inkscape, ungroup everything, and resave as DXF again. Then everything imports perfectly.
Perhaps a there can be a setting for the DXF export feature to reduce the extra step of using Inkscape to process every DXF file.
2 Comments
keqingsong
Thank you for posting your idea! The idea is now 2 years old and does not have many votes, so we are going to archive it. If this is still important to you, please make a new post with the idea included. You can follow the idea submission guidelines here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
