Duplicating CAM Pocket to Contour
I'd like to create a duplicate toolpath pocketing operation, then open up the new one and make it a contour instead of a pocket.  Example, I'm machining some holes and gauge pinning them.  If they're undersized I'd like to create a new program (duplicate) based on the old pocket, but simply open the hole up a bit.  No need to pocket here, just a few contours will do.  However, its nice to retain all my previous info from the prior toolpath without starting from scratch or waste time machining air.
Ben
4 Comments
@Anonymous
Is using the derived operation something that could help you?
http://cam.autodesk.com/tip/derived-operation/
And there it is.
Coming from Unigraphics CAM. Still working out the details with Fusion
360. Thank you.
That's it.  Feel free to close this suggestion.
Regards.
Ben
cj.abraham
Status changed to: RUG-jp審査通過
