Driven dimension monitoring
It would be really nice to be able to monitor the driven dimensions under the "Change Parameters" window.
Within the "Change Parameters" window, under the "Model Parameters" it is possible to see dimensions defined for a component/body. However, it does not show the driven dimensions. For instance, I might like to see the resulting height of a cone model right in the parameters window, upon changing the bottom radius and cone angle, instead of using the inspect feature to measure that every time.
Thank you.
