Drawings visible from model space.
Ok, I don't know if I am missing something here, but why can't I see if a component or assembly has a 2D Drawing while I am in the model space, when I go to the drawing tab, I can create new drawings from Design or Animation, but I can't find anything that indicates that I may already have a drawing,
There I times I look at a printed drawing while in my shed and realize I have missed off a dimension I need. rather than look down a list of to find the drawing, (especially if I have created multiple drawings), I would like to open the the assembly in Fusion360 > Select and Open the component > Open the drawing, that way I know I am using the drawing for that component and not some similarly name or looking component.
1 Comment
How is it?
Shantheman,
Open your Show data panel, (top left 9 dots) in data panel click on the shaded version box, (lower right on your named model). This will then open a drop down type menu. Look in this and see Drawings, pick on the word drawings and it will show you the drawings, if any, that are assigned to your model.
Hope this makes sense?
Cheers
Christopher
