drawing geometry in Drawings
I'm new to 360, having used other solids based apps before I am frustrated at not being able to "draw" lines, arcs etc on a drawing sheet.
Is there a way of doing this?
Is it going to be implemented soon?
1 Comment
Could you give an example?
You can either edit the sketch of the part, or start a new sketch and make all the lines, arc, etc you want. When you edit the sketch, it rolls the timeline back to that point so you can make changes, then rolls it forward again when you hit end sketch.
