drawing export
drawing export
Please add option to export drawings in DXF format.
4 Comments
You can just right click your sketch and select export as DXF...
BBK_CAD
That doesn't help when you need to send a drawing with GD&T and it needs to be in DXF format...
pd700
Seems like a good idea to at least include the DXF and native  .f2d files in the Export command.  I found the  File > Export    command is grey-out and non-functional in Drawing Mode though.  The only export option are  Right Mouse Click or in the second menu line under the Output command PDF, DWG and CSV.
TimeraAutodesk
