Drag and drop and local conversion
I would like to drag and drop compatible cad files (x_t, stp, 3dm, etc.) directly in the data panel column or in drawing area.
Now we have to press the "Upload button"....drag and drop the file....wait the uploading....load the converted file in the working area.
This is time consuming.
I'd like to have local cad translators within Fusion360 that translate immediately the file. The upload process on the cloud can be processed in the background.
regards
5 Comments
Seriously this /\
Both would be great and I'm of the opinion that, in general, if it's not enhancing user experience for something to go through the cloud and it can be done locally, it should be.
charegb
Lot of passion around this topic. The good news is that we are working on this now and expect to support this in summer.
Bankim
charegb
Status changed to: オートデスク審査落選
perfect!
charegb
As of the July update, you can use "new from from file" command to create a new design from a local sat/step/iges/f3d file. We are working on the ability to insert these neutral files using drag and drop next.
