It's often useful to put text on molded parts. Molding typically requires at least a bit of drafting, but the only way I can get drafting to work with extruded text is to go into Illustrator, export as SVG (paths not test), import it, cleanup the things that are wonky (it doesn't come in clean for some reason) and then extrude.
It'd be extremely helpful to just be able to type something out in F360, extrude it with draft and be done.
