draft feature: setting absolute angle value
when using the draft function, one must enter an angle. Yet it actually is the angle by which the drafted surface will be rotated (relative angle) - not the final (absolute) angle between both surfaces.
For example, let's say I have 2 surfaces with an angle of 91° between them. If I use the draft function with the parameter 1.5°, I will end up with an absolute angle (between the 2 surfaces) of 89.5° or 92.5°.
Worse is that I had to discover it myself, because it is not written anywhere in the draft feature box.
I propose to display both values (relative and absolute angle) in the box, and, if possible, to have the possibility to chose between both settings.
Thanks!
