Double Click Joint to Edit Joint Parameters
Double Clicking a joint should open the edit menu for the joint
1 Comment
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this is getting archived due to the nature of workflow.  Currently if you double click on a joint that is not rigid you get the option to drive the joint.  This is as designed, to edit a joint you right click and select edit and double clicking on a joint gives you the drive options.
Cheers,
Mike Prom
