I it would be great if the 2D contour CAM operation had the ability to specify dogbone cuts on all inside corners.
This could be done as a simple checkbox and then a bit diameter number, then the toolpath would be generated to automatically cut a dogbone around all inside corners.
Or... maybe you could select the vertical parts of all inside corners where you want it to be done.
(YES, I'm aware of the dogbone add-in which puts it in the model).
