Display user-parameter comment in window and/or tooltip
I might have missed it, but what is the "comment" field in user-parameters actually used for?par2.jpg
As far as I understand it, it should help identify what parameter is used for what things in order to more easily understand a model later on when editing.
But then, there is no convenient way to read the comments on an existing model, or is there?
I would expect two things when the parameter-window is open:
  • The comment of the selected parameter is shown at the bottom of the window
3 Comments
Oh, and I forgot the 3rd option (potentially instead of the tooltip): Have the comment be a column in the table!
Scoox
I think that column is already available, scroll right in the Parameters window:
@ScooxThanks, you're right! I totally missed that, because the column was completely out of the view. Feeling a bit stupid now 8c)
