Disable timeout while debugging in VS Code
Disable timing out while debugging in VS Code.  Can't debug anything because it times out too quickly. Can't re-run scripts from VS Code without restarting either.  It's a pain because I have to re-open everything and can't remember where I left off and don't have the workspace I left off at.  I literally can't work anything right now.     I can't even debug my importing because not being able to run scripts directly from Spyder has forced me to change the structure of my code and importing.    Also, it would be good to enable running scripts from VS Code in Fusion like it worked in Spyder.
