It will be great if we can do direct modeling from a dead solid as we can in CREO and few new software.
Per exemple:
Re-enter a hole diameter
Re-enter, a distance between 2 faces
re-specify a angle between 2 faces
I suggest that we use the 1st face as the reference face, and the second face as the one that need to be ajusted.
actually, the press pull fonction is not bad, but it's work as a ticken, you can't specified a diameter or distance.
