Dimension sketches with negative values
It would be really good we can dimension sketch objects with negative values.For example if i am giving dimension between two lines(one of them considered fully constrained),when i give negative dimension value i want the unconstrained line to go opposite side of the constrained one.
Fusion have this in sketch offset command already and it would be a real time-saver if it can be added in dimensioning.
Thanks in advance.
