Detatch Tabs into their own window
Right now if I have multiple tabs open, it would be nice if I could detach one of those tabs into it's own window.  I have multiple monitors and am I using another as a reference for what I am doing, so I constantly have to keep switching between the tabs.   If I could drag a tab to another mointor, it would be a huge time saver.
3 Comments
JBerns
That would be more convenient than having to launch a second instance of Fusion 360 and opening the second part in that window.
Jerry
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this is getting archived due to the nature of the request.  Having a tab detach onto it's own window would require multiple instances of Fusion running at the same time.  Multiple instances of Fusion running is not an ability that our architecture allow us to do.
Thank you,
Mike Prom
BrienKing
No it would not.  Having the Tab in another window could still be under the same instance (process).
