DESIGN DRAWING VIEW
DESIGN DRAWING VIEW
1-Fusion 360 would be much more productive, would not waste designer time if it would not change the current view we are when we click to start a new sketch. Of course if we have chosen that view is because we want to start from there. But Fusion 360 assumes by itself that is better to go to another view area, that is terrible annoying wasting our time trying to get back to the previous view.
2-Also like Solid-works for example it doesn't change the view and also it provides us all the time preview views that is so hand to check
points, distances.
3Another and third idea is make Fusion 360 more handy when we are checking distances, angles, etc., I want to mean that Fusion puts
a small grey screen on the top of the measurements we are doing making it impossible to read the measurements, also for example in Solid-works it keeps out of the region we are reading also we can move the little screen by ourselves.
Thank you for your support!
H. Lawrence
1 Comment
HughesTooling
In preferences on the Design tab there is an option Auto look at sketch, you might want to try disabling this.
Also you should only have one request in your post, when you create a new request item 2 of the guidelines is one idea only.
Mark
