Delete and rename default named views + other relevant improvements
As the title suggests, currently we can't delete nor rename the default named views i.e. TOP, FRONT, RIGHT, HOME, which doesn't make any sense since they shouldn't be any different than views created by the user. Basically, all views should be equal and should have the same right mouse button menu.
It would also be nice to be able to re-arrange named views. Currently they are sorted by creation time and users cannot manually re-order them, which isn't ideal.
Finally, it would be good if we could create sub-folders inside the named views folder, for better managements.
Thank you Cat Happy
