decals using image transparency
I just got done with the Skateboard decals exercise--if you're not going to do something with true alpha mapping maybe you should enable transparency in decals using image files that support it, like GIFs and PNGs, so that you can get a sticker which is just the symbol and not the rectangular picture with the symbol in the center.
5 Comments
schneik-adsk
Are png's wih alpha not working for you?
I attached a png with alpha and it works as you described how you wanted.
Having gone back and looked at it--you're correct, I just couldn't get it to work and was probably selecting an image of the wrong type. Smiley Surprised
lure23
Didn't notice this was an old entry, and also did my trial.
Two wishes for the Forums:
1. Could threads (at least ideas) be closed. Like this one.
2. Would it be possible to click off the +1 I gave for this entry. I was hasty. Now it's too late. This is the only forum I know where you can only vote up, and not regret a vote.
Oh, well..
schneik-adsk
This is possible already.
lure23
Thanks, Kevin. Found the 'Remove my Kudos' menu item.
