Decal in project mode
Hi!
My proposal is to add new decal mode - it could be called "project".
The point is to make a task easier and more consistent if one needs to put several labels at once on surface like this:
Single decal PNG could look like this:
Now it's impossible to do as Fusion wraps that PNG around keys and it all got messed up.
Thread on forum with discussion on possible ways to accomplish this: https://forums.autodesk.com/t5/fusion-360-design-validate/put-decal-letters-to-keypad-project-instea...
Alternative ways include:
- put decal on each key at a time - this makes it nearly impossible to align, arrange them and keep them same scale;
- load SVG/DXF in sketch then project it some way to faces then either split faces or extrude and apply some different appearance - highly increase model complexity and contradicts the idea that decals should make life easier for such "decoration" cases.
1 Comment
davidcuesta76
Hi Pavemed,
As you have pointed out the Decal feature is quite tricky to use. I have been posting for about a year to get the decal feature improved. See other posts.
Please vote on them, so hopefully they will improve the Decal feature.
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/decal-improvements/idi-p/6790370
...... I just checked that thread and you have already posted there..... hahahahah
Ok anway for anyone else reading this. Please vote so we can get Decals improved.
Pretty Please..... Autodesk.....
