Datum References and Planes
I like mirroring features in CAD programs, at times I find it easier to model my designs using datum references, setting constraints with objects (parts, sub-assemblies, assemblies and drawings) and being able to mirror those about planes and data references I have created and with the constraints I have with those. I find when I model in that manner I can quickly model something and quickly change something such as a part out in an assembly with how I typically reference it.   I would like to see these implemented into Fusion as well and be able to create a joint to a plane that I could put anywhere or offset and set up constraints referencing the plane as well as whatever object.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
