Im fairly new to Fusion and am currently road testing it for use at the bespoke furniture makers that I work for - so far Im VERY impressed by the 3d modeling capabilities and the ability to quickly and accurately rework models. However from what I've seen so far the drafting environment seems a little rigid and very flat in terms look and feel and lacks any real (company specific) customisation.
Here are some of my thoughts on what I'd really like to be able to edit / customise in order to bring drawings into line with my company's document spec (I've attached some recent drawings produced in a different application below):
- Edit text by block not as a blanket style for the whole document (change fonts, allow for bold, italic, underline, change font colour, add coloured blocks behind text)
- Show colour views without having to export images - these could be shaded colour or even better, textured (showing decals etc)
- Use colours for dimensions and have control over the dim styles - the ones that are available in at the moment dont allow for detailing large items with small details (eg a 4m long bench with a 2mm detail at either end) as the dims just clutter over one another.
- Chain dimensions should be selectable from the start rather than having to draw one standard dim, then select it and start a chain.
- Some more control over where the dimension text goes whilst setting out dims would be good - I find my self having to go back and rework lots positions for chain dims.
- Use of colour generally in drawings would be hugely advantageous.
- The ability to draft in 2d on the page would be very useful (see some example attached) or to be able to use 2d DXF / DWG content. I design furniture and often need to show a 2d set out plan of where the furniture sits in the room / building. At the moment if I adopted Fusion for all my drafting I'd need to use AutoCAD to draw up my plans and (if possible) I'd love to be able to do all of this in one application.
- More control and customization in drawing symbols and labels.
- Ability to show different materials in different colours in section views - this really helps to clarify what's made of what for our workshop.
I'm really enjoying modelling in Fusion and really like a lot of the functionality in the drafting environment, however the drawings that I'm able to output (while they are easy to produce) look like drawings that I was working on 15 plus years ago before we could afford a colour printer - colour and customization is good, I'd like to be able to control drawings and give them my style rather than having to just use black lines, large arrow and the same font across the entire document....
Sam
