Custom sheet size in drawings.
Hello there, Fusion360 enthusiasts!
Due to low budgets we frequently have to print some views of our designs in real size (1:1 scale) so we are able to prototype them, like drilling holes in the right place or cuting a piece of sheetmetal with handheld  tools instead of using laser cut, machining or some other expensive process for example. The problem is that sometimes these designs are a bit larger than fusion would expect and they don't fit the standard sheet sizes that come with the software by default.
My idea is that in addition to the standard sheet sizes you have a "custom sheet size" option where you type the dimensions you want your sheet to have so you can make any design fit in the scale you want!
Thanks for your Attention,
Davi Alves Raquel
21 Comments
brnjon
I'd also like to be able to print sketches 1:1.
