Show only
Search instead for
so if we added a sweep profile library, where you could add your own pre-made profiles it would work for you. We could ship some default shapes like circle, round tube, suare tube.
We probably need to look at twist controls on sweep for this will work right.
That sounds great. You make it sound like a combination of custom edge profiles (Cuts) and the frame generator (Extrudes).
If you made the custom sweep profiles 2D blocks, and the sweep library a single file that the blocks are defined in, this would make it pretty easy for people to add thier own profiles.
