curving surfaces
curving surfaces
I'd like to bend and adapt to the surfaces of existing surfaces.
It is a very useful tool for the design of glasses and more!
[URL=http://imageshack.us/photo/my-images/839/0u34.jpg/][IMG]http://img839.imageshack.us/img839/4744/0u34...
Uploaded with [URL=http://imageshack.us]ImageShack.us[/URL]
9 Comments
deyop
This is an interesting kind of deformation.  We are investigating deformation now which may allow us to do this with a lattice deformer but I like the single surface concept.
I believe that deform a complex surface on a more simple as in the example of the photo is a very interesting technique.
For example, having to draw a pair of sports sunglasses, it is easier to draw them on the frontal plane and then deforming on a surface that takes into account the curvature of the front view and side ... I do not know if I explained it well!  😉
Rhino or in Moi3D is the command Flow
colin.smith
Status changed to: オートデスク今後検討
schneik-adsk
Status changed to: オートデスク審査落選
Warping tools like bend, twist would be the type of tools you are looking for?
even those are very comfortable but I very impressed with this tool
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5893.1
being able to create a surface more simple as the goal of a complex is
greatly simplifies the modeling work
Hi I hope the new bending tool can curve things like the attached screen shot. This is a structure I installed on a ring band surface (about 0.35mm tall from the surface of the ring band). This ring is constructed using Fusion 360 with a lot of workflow which included trimming, changing the shape of a plane, etc.. Then moving the final graphical structure to the surface of the ring. If a tool can do this it will be very good to the designers. Designers have to curve things all the time.
colin.smith
This is in our backlog for conform.  Release date is TBD.
