Hi folks,
here is a quick screencast showing you how the curve network command in Rhino works. Fusion sometimes taps into the same direction like with the loft command but there is a lot more to curve network specifically when you work with complex curve layouts.
I hope the video explains itself well:
https://drive.google.com/file/d/0Byzv_NlyKp_2ZUNqSzh0QnU2RTg/edit?usp=sharing
