When I create a drawing, it is referenced to the global x, y, and z of the model. This works for most parts. However, there are times when I do not want this to be the case. For example, I created a tank with angled sides. When I then create a drawing for thes parts of the tank, it is not possible to align the views to the face of the part (unless I am mistaken). Fusion does not handle this in a way that I consider to be correct.
In the case of this part, I was not able to dimension the diameter of the holes correctly because they are ellipses in this view (due to the fact that the drawing is not aligned with the face of the part). I was able to work around this, but it is not really correct.
Is there a way to align the drawing to a face rather than the global coordinates? If not, it would be helpful if this feature was added.
