The title says it all. There should be an option to select arcs and splines for text to follow. Along with that there should be an offset to the selected line, as well as character spacing. If not that, give the option to select a center point, radius, and start angle.
Going into Inkscape or any other piece of software is not a good solution. Even if it was a separate command like in Inventor we need to be able to do something as simple as this in Fusion alone. There are quite a few posts about this and some of these posts have hundreds of votes, and comments saying how useful this would be. It appears the past attention to this topic has been completely ignored by development. What's the point of the idea station when there's this much support and no implementation? I saw less support on thread milling starting angle that got implemented earlier this year.
