Create list of permanent measurements
Hi, I've created a model with multiple dimensions, and need to then acquire from the model multiple angle and distance measurements.  Currently as it stands, the Measure tool only gives this information while the pallete is open, but it would be great if the selected angles and distances to measure could be listed in the Analysis folder in the browser tree, and could even be given custom names.  This way, when the model dimensions are updated, the list of measured angles and distances under Analysis folder, now with new values, could be quickly identified, and even copied to the clipboard (the whole list all at once).
Just a thought for a little more convenience 😉
Jesse
3 Comments
brianrepp
Status changed to: Gathering Support
promm
Status changed to: RUG-jp審査通過
 Jesse,
Thank you for your idea, this is getting archived due to lack of votes.  I wanted to also let you know that we have something similar in our backlog that might provide you with what you are looking for.  The feature in our back log would allow users to select parameters to be displayed in the browser in a folder.  This would allow users to quickly access and changes model parameters.
Cheers,
Mike Prom
That's fine, I sinced moved on from actually needing this, including by using drawings.
Jesse
