Would be usefull to have an arc tool that let's you specify two points and radius of the arc that passes through those two points.
Use case: I need to be able to create a profile that is an arc of 25 and 15 foot radius and passes through two end points on the part which is being cut.
Currently, to do this I must calculate the height of the arc based on the radius and endpoint distances (using an external calculator) and then set the third point at this height using an offset construction line.
Would just be much simpler to click the two end point and type in the diamater value.
