Counter bore tool fix (CAM)
The counter bore tool right now doesn't have included 2 more dimensions which are important (check image - i have drawned with red color those two missing dimensions) and visually the tool is not the same as on geometry shown...
This make troubles to me and i believe it makes to others too.. i always have to add offset bottom height, so i can get enough deep hole..
I guess that is little work to fix that, but would be huge advantage for making counter bores.
Thank you in advance!
