Copy holes
Copy holes
The hole tool is great, despite it I did not find how I can copy a hole. For instance for a body that has symetrical shape, I spend time to create holes for the right side with the needed precision in positionning and as i can not copy let's say the 6 aligned holes i just created, i need to do the same for the top, for the left and for the bottom. It would be done in a snap if we could copy paste holes.
3 Comments
HughesTooling
You have several ways to do what you're asking for. You could use pattern, for object type you can use Feature and select the hole from the time line or Face and select the face on the model.
Here with copy feature.
Another option is mirror here using mirror faces.
Mark
AD - I'd consider this another vote for an improved symmetry / design intent system
francisr6
Thanks a lot for those informations.
