Copy command for sketches
Can we get a copy command for sketch lines, one that is similar to Revit or Autocad? Hitting the move tool to then select a checkbox for create copy, selecting a pivot location and then moving the whole thing is just too cumbersome, especially since it only creates one copy.  Instead, I prefer to select the linework you want to copy, click on the point from which the lines will be copied, then click on the destination (and optionally repeat). The tool does not have to create parametric copies as that's what the pattern tool is for. Copied linework can later on be constrained, but allowing users to make copies speeds up the workflow.
1 Comment
HughesTooling
You can get something similar if you select the geometry, right click then Copy from the menu or just select then Ctrl+C Then use paste from the right click menu or Ctrl+V. Your request has come up several times but stuff like this takes forever to be implemented.
Mark
