I have ran into several situations where I have copied and pasted components but needed them to update parametrically. I believe that the copy and paste feature should have editable translate information so I can put in values from parameters, or at least edit the translation manually.
I feel this also helps out with more complex arrays of components, which I use often. This involves translate and rotate, which I do not want to write a script that could be solved easily this way.
