Another of the many needed Construction options (really a major overhaul needed) is a Construction point on surface constraint. The current selections are too limited and no constraint is currently allowed that contains non planar surfaces. I'm currently needing to place a point on a nonplanar surface thru a line. I would normally do this in SW via a 3-D sketch, but the current form of 3-D sketching needs to be upgraded to be real 3-D sketching.
As with previous ideas about combining construction plane creation into one feature, so to does point creation need one complete dialog to be able to set up any combination of constraints needed, and not have to pick from the short list available which is even shorter as who needs a construction point on a vertex when the vertex is there to select to begin with?
