When sketching, if I deselect "Work Geometry" in the SELECT->Selection Filters menu, I can still select construction lines.
Likewise, when I select "Work Geometry", but don't have "Sketch Curves" selected, I can't select the construction lines.
Construction lines should be considered to be work geometry, or else there should be an option to filter them.
Sometimes, actual sketch lines overlap construction lines and it is hard to pick them apart when copying, mirroring, etc., so I'd like an option to filter them out of (or in to) selections.
