constructing drawings with more than one constraint
Hi all, I'm sure some of you are familiar with Solidworks and how you can construct lines/ curves with multiple snapping points, I want fusion360 to do that, at the moment I can only construct lines/ curves with one snapped constraint. Drawing to mid points always works, but usually not to end points.
6 Comments
The Blue dot is where the line is successfully referencing a point, and the red dot is where I would like the reference to understand, shaded region is area of image in question
Yeah this has been an issue for a long time and drives me insane. Snap targets are flaky and half of the time I can't even snap to the grid.
colin.smith
On the list of snapping improvements for sketching.  Release date TBD.
promm
Status changed to: RUG-jp審査通過
Thank you for your idea, this is getting archived due to lack of votes.
Cheers,
Mike Prom
keqingsong
Thanks for you idea! We have this in our development plans but do not have an accurate timeframe on when this is available. We will definitely keep you posted and talk about it on our blog when it comes out.
Cheers,
Would like an update on this, as this is the only problem I'm having with using this softwares
