Make move operations under Model more comprehensive in both Modify and Sketch. 1) TurboCAD has a an operation that will move, rotate, and scale, and if I remember correctly, even copy while doing it. This is really a nice time saver, even if it is a little confusing to learn at first. Of course, you can limit the tool to just one of those primative operations, which makes it easier. It also has multiple ways to define each operations as Fusion does. 2) Allow for defining a point as a rotation axis in sketch when rotating, in addition to a line. Maybe this is possible, but I have yet to be able to do it. I am not even sure why rotating around a line in a 2D Sketch makes sense, but it was all I was able to do when practicing today. If this is user error, certainly ignore this idea. Thanks for your consideration.
