Currently when you use the Joint command in an overall assembly, you cannot see the other components that are attached to a specific component you are jointing. For clarity the structure can look like
- Master Component
- Component 1
- Component 2
- Component 3
With components 1 and 2 jointed together. Then attempting to put a joint between components 2 and 3, component 1 is not visible to see the spatial relationship between component 1 and component 3. It would be very useful when doing a series of joints, especially rigid joints as they are used to do layouts much of the time, to see all components that will be affected by the new joint so we don't have to do trial and error to correct joints that have an incorrect layout.
