Component properties panel needs measure value adjustment
Would be great to have drop down menu for different value formats in the "properties analysis" window of an object - when you go over an object, right click "get Properties".
I design in MM usually and yet when I mold/cast I use cubic inches for fluid scale measurements. So having to exit the properties pane to switch the scene dimensions from mm to inch to check properties and then back to continue designing is teasious. Offer a little box to show values in mm3 or inch3.
Thanks Alldaron
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
